0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I was heading to a BBQ with some car and truck fans in my '50 3100 with a 235 and a Carter YF2100 and lost git up and go trying to go 50 MPH or more. I pulled out the choke until I found a sweet spot and got most of my power back. I pushed the cholke back in when I came to stops so that I wouldn't soot up my spark plugs. The choke method worked fine the rest of the way to the party and all the way home which was fifty miles. I figured that there was dirt in the main jet, since pulling the choke knob forced gas to be sucked from somewhere else in the carburetor. I took it apart and found a 1/4" long skinny piece of rubber in the main jet hole nearly plugging it up completely. That small rubber piece came off of the accelerator pump shaft seal. If I would have had an automatic choke instead of the manual choke, I wouldn't have ever made it home that day. I love these trucks.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Congrats on making it home. Have yet to encounter such a problem with my truck but one never knows what might happen tomorrow, etc.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | I love it. The simplicity of these rigs is just the best.
Worst case…..if one were so inclined, a single flat screwdriver would have the carb apart in a couple minutes. Maybe add one wrench to that tool list if you wanted to take the carb off the manifold.
1951 3100
| | | | | Joined: Feb 2019 Posts: 4,478 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,478 | Worst case…..if one were so inclined, a single flat screwdriver would have the carb apart in a couple minutes. No, the worst case would be (and this is what I envision would happen to me), dropping a screw/part attempting that repair. I believe Carl did the right thing by getting it home, when he could work on it in a more controlled environment.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | No, the worst case would be (and this is what I envision would happen to me), dropping a screw/part attempting that repair. Yep, right down the carburetor throat.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,450 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,450 | ... while the engine is running ....
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | A lot of people have wondered why these trucks have a throttle and choke cables. I just found another good use for having choke knob.
One time I had a hole form in the accelerator pump diaphragm of a YF2100 which cause an extreme rich condition to the point that it would stall at idle from an extreme rich condition. I pulled the throttle knob out just far enough to keep the engine running while not moving. This allowed the excess gas to be burned instead of drowning my spark plugs. And, once again, I made it home just fine.
| | | | | Joined: Oct 2021 Posts: 6,775 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,775 | I forgot to put the cotter pin/clevis pin in the gas pedal rod where it attaches to the linkage. Of course it worked its way out on the freeway and I had no response from the gas pedal. It was too hot to even hook it back up and stick a makeshift pin in place so I drove home working the throttle on the dashboard.
That was tricky to do while steering and shifting gears. I made it home - about 6 or 7 miles on the interstate and sorted it out when it cooled down.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Did you grow up on a dairy farm Otto?
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | You did what every dairy farmer has to do on a daily basis to keep everything going in between milking cows twice a day and pulling calves out in the middle of the night.
| | | | | Joined: Sep 2009 Posts: 5,856 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,856 | Back to the topic at hand please fellows.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
