1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I recently found and inherited my great grandfathers hand POWERED (yes, that means manual) drill press. It says "champion blower and forge company Lancaster PA" on it. It uses a bit with a flat side and a set screw to hold it in. My dad has used it several times and says he has drilled thru 1/2" metal without a lot of effort. My questions are : does anybody know how old this is? My dad told me his grandfather, who died in the early 40,s, said he bought it second-handed in the 20's. Any ideas on websites that might help? Also, can i find bits for it? I am considering having a machine shop make a shaft that will fit and tap the end for a modern chuck. I am not concerned with the value, just think it would be neat to use a tool that my great-grandfather used,who was a wagon builder. Thanks! | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | IMHO, this is a family heirloom and therefore priceless. You are a lucky man. This past Saturday I saw a human powered drill press in use on the PBS show The Woodwright's Shop. You might drop them an email or better information forthcoming on this site, move it to The Greasy Spoon for more exposure?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Thanks. I will try the the spoon! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | blu - they're called "post drills", had a big one in a shop I worked with had bits to about 2" - from waaaay back, maybe 1700's in "industrial" England - commonly used by blacksmiths well into the 1900's - I think Champion is a fairly common maker of ones still found around the US today - they are quite a good machine if they, included "auto feed" like most used in machine shops for metal - a little about adding a chuck Bill | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Thanks!!! Mine is not exactly like either one of those, but that is it. The ratchet arm is broke, otherwise mine works well. With these pitcures, i will be able to fix it!! Ain't the internet grand!!! | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If you want to convert your chuck to a modern Jacobs style chuck check out ebay for a 1/2" chuck with a 1/2 straight shaft like they use in a milling machine. If ou have acess to a lathe you can make the straight shat adapter your self and use a chuck from a old 1/2" electric drill and do it on the cheep. You can braze the ratchet arm back togeather but be careful as the metal is realy old and sometimes brittle. I have a old post drill that i use every day and have grown to love it. When you go to set it up take great care to get the table square with the chuck. Take care of it and your grandchildren can pass it on to their grandkids. If your intersted in smithing I think there is a blacksmith club in yor area called BAM. | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Thanks for the tips. I am really interested in getting this thing working again. Any idea where that club is from? Probably don't have the time for another hobby, but sounds kind of interesting. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I'm not sure where it's based at I'll check on it at our next blacksmith meeting. I might be able to help if you need smith tools or other such tings. By the way I go by your area on the way to see my daughter any good old time junk yards in your area. All the ones around here have been picked clean. | | |
