2 members (Tinker5, klhansen), 121 guests, and 3 robots.
Topics128,193
Posts1,057,256
Members48,466
I'm currently working on a 270 GMC and fitting a turbo. I have a big port head, so my question is that the 270 exhaust manifold doesn't fit the big port 302 head. With the exhaust mounted to the head it comes right up to the bottom of the intake port covering all but about a 1/16 of the sealing area of the port. I'm thinking a large port head, 302 or 270H has there own exhaust manifold ???
Jay D.
Do you have some pictures? That would help make it clear what you are asking.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
here you go.
B Online: Content
What is the casting number on the exhaust manifold? There are many exhaust manifolds listed for 270/302 engines in the 39-54 and 55-60 GMC Master Parts Books. Sometimes you get lucky and the part number is one digit different than the casting number.
thanks for the reply, sadly i ground off the numbers. i was going to have it coated and want it smooth.
Jay D.
You may find that the exhaust manifold isn't lining up correctly with the ports in the head. I have had several manifold and head combinations where this is the case.If you are using the 3 piece intake/exhaust gasket. bolt it to the head, and then tape all 3 peices together. Now lay the gasket on the manifold and see if the ports line up. You may have to elongate the front and back mounting holes. I have also have had to install a spacer between the exhaust and intake manifold where they bolt together for all the ports to line up correctly with the ports in the head.
gmc-is-me
just retired and finally making headway on my project truck. 1940 GMC AC152.
It might be necessary to make snug-fitting wooden plugs in the shape of the exhaust ports and use a die grinder to match the manifold to the head openings. That's a trick we used when porting heads and headers/exhaust manifolds for round track engines. Once the ports are matched up, them tweak the bolt holes to fit.
