4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
I changed the oil on the '60 261 in my '53 3100 and put in 6 qts; 5 for the crankcase and 1 for the bypass filter. After running it a bit I Checked the level & found that I'm 1 qt high and the filter is dry. Where's the most likely spot for the clog, in the line to the filter itself?? Thanks for any tips you can offer.
Denny
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
It’s gotta be upstream of the filter. Are you running soft lines or hard?
Could probably disconnect the feed line at the canister and blow some compressed air back toward the engine?
1951 3100
AD Addict & Tinkerer
Most likely it’s clogged where the supply line goes into the block, a common problem. It’s the line closer to the firewall. I would disconnect that line from the fitting and the filter, then blow thru the line. Then I would use a drill bit (by hand) to try to clean out the port that goes into the block.
Phil
Project Journals
Stovebolt Gallery Forum
I've got soft lines. I'll blow them out & will clean the ports where they connect to the engine. Thanks
~Denny
1953 Chevy 3100
H Online: Content
Soft lines are a really bad idea. The only reason they were used on the original installation was to make it easier for the optional filter to be installed at the dealership. Replacing them with 3/16" or 1/4" OD hard line would be a permanent fix.
