2 members (Materman, Nick in Manitou), 79 guests, and 1 robot.
Topics128,072
Posts1,055,906
Members48,429
#1579402 06/09/2025 1:18 AM
Hi
Putting out 35 amps
Contacts in regulator are free
Is regulator just shot or is there something I can do to it
Adjust the regulator if it's a Delco Remy. Instructions for adjusting the VR are in Section 12-5 through 12-11 of the 1948-1952 Chevrolet Truck Shop Manual. Specifically adjusting the voltage output Section 12-10.
Clean the points with a couple passes of 1500 grit sandpaper and alcohol.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Be sure you're working with a fully charged battery before attempting to do any adjustment of the voltage regulator points. Chances are the current regulator (behind the "ARM" wire) is controlling the current flow into a low battery at its intended setting- - - -35 amps. You can simulate a fully charged battery with a 1/4 ohm resistor connected in series with the BAT wire- - - -use four 1 ohm 100 watt ceramic resistors wired in parallel to make a high current 1/4 ohm resistor. The correct voltage regulator setting is 7.3-7.5 volts for a 6V system, or 14.5-14.7 for a 12 volt.
www.ebay.com/itm/166845585117?
Thanks you all!
