| | | Forums66 Topics128,053 Posts1,055,778 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 232 'Bolter | | 'Bolter Joined: May 2019 Posts: 232 | Hi
Putting out 35 amps
Contacts in regulator are free
Is regulator just shot or is there something I can do to it
Thanks | | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | Adjust the regulator if it's a Delco Remy. Instructions for adjusting the VR are in Section 12-5 through 12-11 of the 1948-1952 Chevrolet Truck Shop Manual. Specifically adjusting the voltage output Section 12-10.
Clean the points with a couple passes of 1500 grit sandpaper and alcohol.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Be sure you're working with a fully charged battery before attempting to do any adjustment of the voltage regulator points. Chances are the current regulator (behind the "ARM" wire) is controlling the current flow into a low battery at its intended setting- - - -35 amps. You can simulate a fully charged battery with a 1/4 ohm resistor connected in series with the BAT wire- - - -use four 1 ohm 100 watt ceramic resistors wired in parallel to make a high current 1/4 ohm resistor. The correct voltage regulator setting is 7.3-7.5 volts for a 6V system, or 14.5-14.7 for a 12 volt. www.ebay.com/itm/166845585117?Jerry
| | | | | Joined: May 2019 Posts: 232 'Bolter | | 'Bolter Joined: May 2019 Posts: 232 | | | |
