8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup), 111 guests, and 3 robots.
Topics128,154
Posts1,056,835
Members48,456
My truck has the GMC inline 6 and I’m just cleaning up some things in the engine bay.
I noticed the coolant hoses don’t look to be in original location (or at least based on what I’ve seen in other photos).
Any idea why they would be in this configuration?
My engine is first 3 photos… last photo is one I pulled from online.
The hole on the top rear of the head (where your heater supply hose is attached) is used on big trucks to supply flow from the hottest area of the head back to the water pump. Most small truck heads don't even have that hole drilled and tapped. The line on the big trucks was metal, not rubber. That said, this arrangement probably works well and would prevent trapped air at the back of the head.
The valve cover was designed for a PCV equipped truck, not a draft tube equipped engine like yours.
... and you really should pitch that Chevy carb. Not even the Chevy guys like them. wink
Thank you …. What do you recommend for carb?
i'm sorting out hoses also, in the last picture the 2 hoses that come off the water pump to the heater. are they suction on the lower hose and pressure on the top one??
Ther upper hose isn't at the water pump- - - -that's the thermostat housing. It delivers pressurized hot water to the heater core. The lower hose goes into the suction side of the water pump, and is the return line from the heater.
thanks for the reply
Jay D.
