2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Gonna be replacing my old valve cover gasket (after I adj the valves) with a new Fel-Pro 7/32" VS50190C with plans to glue it just to the head, keeping the top side (valve cover side) clear and dry. What sealant is suggested?
Craig
I use 3M trim cement to stick the gasket to the head, and a thin layer of general purpose grease on top to make sure the gasket doesn't stick to the valve cover. It's usually good for 2-3 valve adjustments that way before it needs replacing again.
I used Permatex #2 between the gasket and the head and left the gasket to valve cover surface clean and dry. I have other oil leaks, but not around the valve cover.
Most oil leaks from a less than perfectly straight valve cover seep out between the gasket and the head.
By using adhesive between the gasket and the head, you shouldn't have any leaks.
There isn't enough oil going to the rocker arm assembly to ever flood to the point the it would make it over the top of the glued down gasket.
Thanks all for the replies. It's been a VERY long time since I've replaced the valve cover gasket. Just want to see if there's any new methods.
Craig
Like the weather strip adhesive?
1951 3100
