7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,687 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,687 | Baffles? Maybe some sort of packing? Or is it just a straight hollow passage?
Thinking about a little project related to my PCV setup. Want to know before I start hacking away at a draft tube.
1951 3100
| | | | | Joined: Oct 2021 Posts: 6,817 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,817 | I think it's mesh like an air cleaner.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2007 Posts: 3,397 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,397 | It has a mesh screen and a baffle. The mesh screen wraps around the inside of the canister, the baffle mounts above that just below the down tube. I used mine to make a PCV, I cut the down tube off and welded up the opening using a small metal plate. I cut a 3/4 inch hole in the top of the canister and added a valve cover grommet. I welded the down tube back on just to complete the look of the original . Sorry, I thought I had pictures of the set up, well not on this phone. https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1560637/3
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
