4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
I need a 1956 Chevy 3100 3 speed transmission tail shaft rear seal. Measures 2 3/8" X 1 1/4 "
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Thanks Bill. It's not the same size but but it's close. I'll give them a call.
Mickey - The original seal is GM# 3746212. The same seal is used for the standard 3 speed in your truck plus it also fits Powerglide transmissions from the same time period. You can find a few NOS seals offered on eBay as well as other vendors with aftermarket replacements. A couple of our usual vendors are listed below.
The Filling Station sells them as a Powerglide Rear Seal
Jim Carter offers them as a 1955 and later 3 speed/Powerglide/Turbo 350 rear seal under PN: ME505
~ Dan
1951 Chevy 3 window 3100
Dan I've been searching half a day. Should of known you'd have the answer. Got 2 (just in case) on order at the "Filling Station".
Thank you.
Also available at Auto Zone. P/N 9613S about $4.00
Thank you.
No problem Mickey. You know I enjoy researching the info and being able to help out when I can. BTW - Your original ID (Inner Diameter) you listed above of 1-1/4" is a tad off. The correct inner diameter for the seal is 1-1/2". Bolter rfs56trk is also 100% accurate that the seal "P/N 9613S" is correct for your application too. You can see that number cross references to the original GM# 3746212 (among many others) if you scroll down this finditparts.com part details page. They also provide detailed measurement specs for those interested in that level of detail. smile
~ Dan
Thanks Fred. I'm finding out part of the problem is "punctuation ", a listed item may show it fits a
"3 speed Powerglide", TH350, Hydromatic, etc. Makes it look like it only fits automatics.
