Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
That's $2000 in today's money for the Chevrolet. Still a bargain.
1950 Chevrolet 3100 (Ol' Roy)
Interesting that you get the whole engine with the Ford and Plymouth but you don't get the head with the Chevy.
Particularly given the amount of time needed to adjust the valves properly in the Ford flathead engines.
Once purchased a reman Ford flathead V8 that used adjustable lifters. This was probably Sears' way around the issue of grinding valve stems to set valve clearances.
Mr. Parker (1963-64 Auto Shop teacher at Spring Branch High School) taught us how to do valves on a flathead f0rd, and then showed us how to install the adjustable lifters.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
Nobody had ever seen a flathead Ford when I was in high school auto shop, let alone knew how to adjust the valves on one.
Gentlemen, please keep this on track! No more talk about furds!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Utah -- you *are* old if I'm reading that card right ... it expires on August 4th of 1939?
~ John
1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 1963 Kaiser M38A1 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
