3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#157835 03/05/2006 2:21 AM
I
I Offline
Some of you may blast outdoors, and ran acrosst the problem of needing a hood, to protect your face. If you have a welding helmet already, its easy to remove the colored lense(keep in the clear ones) and just tape a bath towel around the back edges. Its cheap and works better than some of the fancy store bought ones. I have one of the fancy ones too, but it always fogs up inside, and you can't see.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#157836 03/05/2006 3:58 AM
Jeff
I do the same thing, only I cut a piece of glass to replace the lens and I ripped up a old sheet. I made a air supply with a bathroom fan a ABS adpt. and a central vac hose. The helmet doesn't fog up and it help keep mask clean. Small world. Jeff
New deal for old steel
#157837 03/05/2006 4:17 AM
I
I Offline
Your not blowing outside dust laden air into your helmet are you?
Jeff
1953 3/4-ton
#157838 03/05/2006 4:27 PM
No the hose is about 40ft and I put a flat air filter from my wife's car on top.
Moderated by  MNSmith
