5 members (Rich'sToys, Charles in CA, Stovebolt48, Hotrod Lincoln, 1 invisible), 106 guests, and 2 robots.
Topics128,151
Posts1,056,994
Members48,460
At least 1 of 2 on my truck is toast. Going to replace the two rears when I do the front engine mount.
So as I go shopping and referencing various part numbers….I stumbled upon a “heavy duty” rear mount option. Are these compatible with a 1/2 ton truck? Or only larger trucks? Anyone ever used them?
Mostly just asking for curiosity’s sake. I’m not likely to spend the extra money it would take to buy these, even if they did fit.
This is the type that’s on the truck, and what I had in mind when I started shopping: (just for reference, not my listing) https://www.ebay.com/itm/233769114057
This is the “heavy duty” type that I didn’t know existed: (again - not my listing, just reference) https://www.ebay.com/itm/226458701346
Last edited by Gdads51; 05/21/2025 2:15 PM. Reason: remove tracking from ebay links
1951 3100
Nathan - The GM# 3711027 Rear engine mounting unit (Heavy Duty) are listed as a heavy duty option unit for 1938-53 Utility Trucks which are 1-1/2 ton and up (including COE). So short answer is no, the HD parts aren't compatible with your 3100. I've actually never seen the HD units on any of the Big Bolts I've looked at, so far.
~ Dan
1951 Chevy 3 window 3100
Did the big bolts you saw have the “conventional” style like the first link I posted? Or something else?
1951 3100
U
U Offline
Mine look like this on my '46. (JW51 - Trying to send you a PM, but it says you're over the limit?)
~ John in Utah
Here We Go
Follow in his DITY Bay
Made some room, Utah.
1951 3100
Nathan - All the Big Bolts I've seen so far used the conventional mounts.
~ Dan
So….heres my theory:
If the conventional mounts fit the Big Bolts, then those HD mounts probably fit the 1/2 ton Bolts.
As weird as they appear, if you study the assembly diagram in some of those eBay listings….its two bolts horizontal into the bell…and one bolt vertically into the frame. Just like the conventional ones.
If they weren’t so daggum expensive, I’d buy a set just for science.
1951 3100
They certainly are expensive compared to the standard mounts. Below are a couple better pics from this evilbay ad of one side mount unit along with the diagram and install instruction sheet for anyone interested in seeing them.
~ Dan
