| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15776 07/26/2004 11:21 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | After a rebuild of my Rochester on my 1950 216, I still have leaks where the top meets the bowl. This is apparently a design flaw. It was suggested that I get a Carter to replace it. Can anyone tell me which Carter to get and if anyone has a good used one I can rebuild? | | |
#15777 07/26/2004 11:51 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Check out the topic Chevrolet Carter YF carburetors posted 24 May 2004.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
