4 members (Ridgeback, Gdads51, Woodcmiami, Wayne67vert), 99 guests, and 0 robots.
Topics128,049
Posts1,055,651
#1575074 04/14/2025 3:09 PM
looking for the latest recommendation on what make and where to purchase a replacement mechanical fuel pump
1957 3100, 235 engine with dual Rochester carbs
Thank You
Blue 57 #1575077 04/14/2025 3:51 PM
Crusty Old Sarge
Crusty Old Sarge
Good morning, A lot of folks are rebuilding their stock pumps with kits from Chevy of the 40's or Then and Now. I have an aftermarket Carter on my "58 4400 , so far I have had no issue. I purchased this one at my local OReilly's.
https://www.chevsofthe40s.com/detail/7906/Chevrolet_Chevrolet_Fuel_Pump_Rebuild_Kit.html
https://www.then-now-auto.com/product/fpa-245-fuel-pump-kit/
I'm just south of you in Bruswick.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Blue 57 #1575086 04/14/2025 5:25 PM
Sir Searchalot
Sir Searchalot
NAPA
One year warranty. Rebuildable with hex bolt closure.
Blue 57 #1575104 04/14/2025 10:13 PM
U
U Offline
I used a kit from Then and Now to rebuild my glass bowl pump. But if the NAPA pump is rebuildable, that might be a good choice.
~ John in Utah
Here We Go
Follow in his DITY Bay
Blue 57 #1575106 04/14/2025 11:13 PM
Sir Searchalot
Sir Searchalot
A new fuel pump from NAPA is cheaper than a kit. It has a warranty for a year. The pump kits have the same Chinese parts that most new pump have. There is a chance of messing up the kit install into your old pump, if you have one. I don't know what pressure it takes for two carb bowls, this NAPA pump has 5 psi.. It's a local buy and easy to take back with no shipping, Free delivery if less than 5 mi from the store. It's Delphi and says "United States"
Reason for above comment/opinion:
The best you can do to make a choice now-a-days is to mitigate small headaches, factor in best bang, due diligence, return difficulty, warranty, reputation of seller, rebuilt vs new... as I did above. I buy from everywhere, not just NAPA.
Last edited by bartamos; 04/15/2025 12:15 AM. Reason: punctuation/added reason for comment
Blue 57 #1575116 04/15/2025 12:43 AM
G Online: Sleepy
Delphi MF0073 Mechanical Fuel Pump used on my 1957 235.
I bought 3 when they were cheaper than now.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
TUTS 59 #1577502 05/17/2025 4:56 PM
Hello Thank you all for your responses
It is much appreciated!
Blue 57 #1577504 05/17/2025 5:21 PM
While having good fuel volume is important, running dual Rochesters on a 235 is WAY overcarbureted unless the engine is highly modified. Good luck!
Blue 57 #1577512 05/17/2025 7:05 PM
Moderator, Electrical Bay
Please listen to Jerry. He and Jon H (CarbKing) have for over a decade explained why and how a stock 235 will suffer from overcarburetion. For a stock 235 I suggest a stock intake manifold, a stock exhaust manifold and for the 1957 235 definitely a Carter YF3211S in good nick & adjustment. That Carter is a great improvement over the Rochester B or BC. As for a fuel pump, I have used an electric pump with great success since 1997...about the time fuel pumps in the USA stopped being produced. The pump I use is an AutoBest model F4027. It will output around 3 psi (which is just what you need) and my experience has been the pump lasts a long time. On Amazon currently you can buy one for less than $20 and it is made to handle ethanol-laced fuel. Good luck!
~ Jon
Blue 57 #1577576 05/18/2025 4:37 PM
1 Offline
Regarding electric fuel pumps, buy 2. They are cheap. Install one and put the other under the seat along with a spare filter and hoses. This will save you a tow bill when the pump gives out. I'll spare you the story of changing one in the rain after a tow and a two mile walk to FLAPS each way.
1951 3800 1-ton
In the DITY Gallery
