11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith), 78 guests, and 2 robots.
Topics128,032
Posts1,055,523
Members48,425
#1577202 05/13/2025 12:59 AM
I have a GMC first start problem. Here is what I know:
1) if I fill the Carburetor up with fuel from an empty coke bottle with a hole in the lid it will start and respond to the accelerator. Once the fuel runs out (I’m working alone), it stops.
2) the fuel line are clean and the fuel pump appears to be sucking up fuel from the gas tank but not delivering it to the carburetor even though I just replaced both the carb and fuel pump. The new equipment has resulted in the exact same issue.
Any thoughts?
These days, new parts cannot be counted on to function properly (especially fuel pumps).
Changing two parts at once also muddies the waters when trying to diagnose a problem.
Test the fuel pump by following the steps in in the post below to the letter.
https://www.stovebolt.com/ubbthread...esting-a-stovebolt-fuel-pump#Post1575679
Report back with your findings.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Sun test equipment's motto back in the 1950s still rings true- - - - -"We Test- - - -Not Guess!"
The needle in the carburetor is likely stuck, you can pull the top off or try an air nozzle to dislodge it.
H Online: Content
Rubber tipped (Viton?) float needles have a nasty habit of getting stuck on the seat and choking off the incoming fuel, particularly if an engine isn't run frequently.
