7 members (Gray_Ghost, cmayna, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop, treegrower), 105 guests, and 1 robot.
Topics128,067
Posts1,055,877
Members48,428
#157711 02/19/2006 3:23 AM
well i got one of those gravity/air fed sand blaster pails,about 2.5 gallon jobys with a 4 foot hose.
could a guy build a box with plexiglass front,i was goona cut two arm holes and staple some long heavy duty rubber gloves to that.
would this work?
i'ts minus 28 outside and i want to keep dust to a minimum.
any feed back would be appreciated
#157712 02/19/2006 10:12 AM
You could, and you might try to make the sand trap out the bottom through a labrinth. Use some weather strip gaskets to get it as tight as possible. Make the bottom go down like a pyramid and put a screen over it so the sand will 'drain' out of the way.
#157713 02/19/2006 12:35 PM
well i guess i will build it ,so tha i can start on the small parts,
thanks for the input.
will it be to dusty? what about a shop vac atachement at the top/?
#157714 02/19/2006 3:08 PM
a shop vacum will work fine...if you have alot of blasting to do and have not used the one you have and can return it check into one that is preasure feed((harbor freight))also use fine screened sand,,I use suger sand((sillacate)))works good but read on the sack you should use a good filter when using this...
#157715 02/20/2006 11:25 PM
I made one out of a big cardboard box and a old window pain. I cut a hole on the side corner for the vac and two arm holes. I pulled the sandblaster hose in one of the arm holes and put the window on top. I didn't seal any thing and it was not bad. But you need good ear muffs and clean the vac filter a lot.
New deal for old steel
#157716 02/21/2006 8:31 AM
Mine was extremely simple. I went to a corner of my yard, and drapped a rubbber tarp over the fance and in the grass and then blasted away. Picked up the tarp, screened the sand that was trapped, and went at it again. I have a HF 40 lb pressure blaster that looks like a cold pill with 3 legs.
#157717 02/21/2006 7:34 PM
Heres one I did for small parts...workd OK needs more light and maybe a vac with filter
Dan
http://community.webshots.com/mypho...=1512705909071274430&security=nFZxbR
#157718 02/21/2006 11:08 PM
NICE BLASTING DEVICE..
I JUST LEARNED THE HARD WAY ABOUT SAND BLASTING IN THE GARAGE...
I ALMOST HAD A FLASHBACK FROM SAUDI!!
SAND EVERYWHERE,,,
OH WELL GOT MOST OF THE CORNERS ON THE FRAME AND
MOST OF THE ENGINE...TOMORROW I WILL BUILD THE BOX AND MAYBEE GET AROUND TO DOING THE SMALL PARTS.
A LITLLE AT A TIME I DON'T WANT TO BURN OUT ON IT,BUT HAPPY TO SEE PROGRESS.
Moderated by  MNSmith
