2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
Need some help identifying some parts. 46 1/2 ton rear end. Came with the helper spring kit. Have removed all of the suspension and am installing a single spring pack. On the housing are these “pads”. I believe they were to locate the spring perch collars. They are riveted through to the interior of the tube. My thought is I need to reuse the collars as my perches. I haven’t come across much, if any info on these helper spring kits. Otherwise I remove the pads, weld up the holes, and weld on new perches? Thoughts or information? TIA.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
U
U Offline
I had my axles apart this past winter and learned that if you are keeping the torque tube, these collars allow the axle to rotate when it goes up and down. If you are going to an open driveline with a U-joint at your pinion, you may not need them.
~ John in Utah
Here We Go
Follow in his DITY Bay
If you're going with an open driveline, you HAVE to somehow fix the axle housing to the springs after setting the pinion u-joint axle. Either remove the collars and weld on spring pads or some other method to keep the axle housing from rotating.
If you are keeping the torque tube, Utah York provides an important note about the collar function. If you do stay with the torque tube and still want to eliminate the helper springs, you will need to locate another axle with the correct 2 piece collars. You'll also need new shorter U-bolts. The non-helper spring collars were side specific per the 1929-46 Chevy Parts Book.
Seat w/cap, Left GM# 600175 (373345 cast on cap)*
Seat w/cap, Right GM# 600176 (373346 cast on cap)*
* Both parts listed to fit Chevrolet 1936-46 ALL 1/2 ton Commercial trucks
~ Dan
1951 Chevy 3 window 3100
