Trying to decide on new wheels/tires for my '55.2 3600 that has stock 15" wheels on it now. Wheelsmith only has 16x6, 7, & 8" in 8 lug. The 16x6 can be had with 3 1/2" backspacing, which is very close to stock 15" backspacing and offset. I think these will clear the tie rod ends. This is what I'm leaning towards right now; hoping I can tweak caster to compensate somewhat for geometry difference if needed. The 55.2's 3600 had options for 15", 16" & 17" wheels; I don't know if factory caster was set differently with each option. Haven't seen any documentation that would indicate this. Anybody have any thoughts on if caster may need changes?
Last edited by Gdads51; 05/04/2025 9:23 PM. Reason: edit to separate into it's own conversation (TF different than AD)
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
