3 members (Otto Skorzeny, Pre '68 Dave, BCBill), 289 guests, and 1 robot.
Topics128,101
Posts1,056,178
Members48,436
#15764 11/25/2001 4:51 AM
I have two engine Serial numbers that I cannot identify. They are for 6 cylinder engines, they are KEAI37870 and F806B can anyone identify these? Any links?
todd simpson
#15765 11/30/2001 8:54 PM
Your second engine is: 135-145hp 235, from '58-60 (up to '62?) 8.25:1 compression ratio with Powerglide tranny built on August 6th in Flint.
The first engine number you mentioned I can't find, but I have a reference for a '52 216 that reads KBA, maybe you mistook the KBA for KEA?
If you really want to pinpoint the year of your engines, there is a number cast into the block by the starter (at least on 235's)
Example: H216
Reply with that and I'll help you out some more. They should both have a similar date casting on the head under the valve cover; The block is your best bet since the head may have been swapped.
6 > 8
-Keepin' Things Inline-
