Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#1576245 04/30/2025 1:21 PM
I recently had a new fuse block and new under dash harness kit installed. The lights worked for a while but have stopped working. New headlight switch and dimmer. Should there be power to the dimmer switch with the headlight switch on?
Thanks in advance,
Mark
ole green #1576247 04/30/2025 1:46 PM
If the "new fuse block and new under dash harness kit" is anywhere close to the original wiring diagram, yes there should be power to the dimmer switch when the headlight switch is pulled all the way out.
ole green #1576291 04/30/2025 8:48 PM
I rewired my headlights from the dimmer switch to the headlamps a couple years ago. Prior owner had the three wires on the dimmer mixed up so lights only worked on hi beam.
What year and model are you working on?
If it is 6v, you must use 12ga wire as a minimum.
Do the headlights work at all on either hi or lo beam?
1950 Chevrolet 3100 (Ol' Roy)
Bill Hanlon #1576335 05/01/2025 2:27 PM
12volt. 1960 C-10 No. I have no power at all.
Mark
Bill Hanlon #1576339 05/01/2025 2:37 PM
Well it should be. A reputable mechanic that has done work for me in the past installed it. I was trying to troubleshoot a little because they didn’t touch the headlight harness. The headlight wires from the connector on the firewall to the connector on the core support have continuity so I don’t think it’s the headlight harness.
Mark
ole green #1576354 05/01/2025 5:29 PM
Start at your fuse block and see if you have power to the circuit feeding the headlight switch, then check with the switch on at the output wire, then down the line toward the dimmer switch and headlights. When you get to the point where you have no power, back up and fix that component.
ole green #1576362 05/01/2025 7:25 PM
Question: Do any other lamps that run off the headlight switch work? Dash, tail, parking?
ole green #1576594 05/05/2025 2:28 AM
Turns out I had a bad switch. Thanks everyone for your advice.
Mark
