2 members (R&S 51 GMC, Tiny), 152 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
#1576314 05/01/2025 1:53 AM
I have a 350' chevy 4 bolt main block with 2 sets of caps. Bothe sets are numbered 2,3 and 4 but I am sure you already know my question. I have cleaned up the block and bothe sets of caps. I have installed bothe sets separately. I don't ever remember having to tap them in with a medium sized hammer, so how do I determine what set is going to work? My smart _ _ _ buddy's said to toss a coin heads or tails? These caps were wired separately in a wooden box, I can't remember how long I have had the 350, I am sure the early 70's.
Unless they were original equipment to the engine, they will probably have to be line bored to fit the block. Finding an alleged "machinist" willing to do the job will be the biggest problem.
Hotrod, what about the light tapping with a hammer to seat the caps in the block?
That's normal- - - -they're supposed to be a snug fit. It keeps the cap from shifting sideways, and keeps the bored hole perfectly round. Now, if it takes a medium velocity swing with a BFH, that's what we call "too tight!" You can chamfer the corners of the block and/or the cap VERY slightly with a file to help guide it into place. The aftermarket 4 bolt caps I used to install on 2-bolt race engines were intentionally made a few thousandths too wide to compensate for manufacturing tolerances between blocks, and had to be file-fitted, then line bored.
