7 members (Gdads51, 68ironhead, PAUL Berardi, Joe H, 3B, Jon G, JW51), 194 guests, and 2 robots.
Topics128,103
Posts1,056,188
Members48,436
In regard to attaching the angle strips to the bedsides, I have no problem welding them on similar to the originals. But, I'm wondering what would be the disadvantage, if any, to attaching them with small bolts? Most of them would be under the fenders where they wouldn't show. It seems like that might have some advantages over welding, but I thought I'd check on here before going any further.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I chose to bolt mine on to provide a little flexability in the bed assembly process. There are 2 bolts that have exposed nuts (not covered by the fenders) on my 3600 which is (I believe) a long bed. If your truck is a short bed there may be less. I am using shortened bolts with acorn nuts on the exposed bolts.
1949/50 3600 Project
Follow in Project Journals
Mine is a short bed but, at a glance, It still looks like I'd have a bolt or maybe 2 that would show in front of the fender. I like your acorn nut idea. I may go that way too. I'm not building a show truck any way. I just want to end up with a reliable old truck to use as a local driver for the rest of my days. Thanks
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
RLB Offline
On my 66 short stepside, I used SS bolts & painted them along with the rest of the bed . Looks good imo and I’ve not had one person comment on them. Most people won’t even know the difference .
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
I bolted mine with SS with the head outside. Just left them SS. Only 2 show on the outside, same as RLB. I'm happy with it.
Dennis
40 Chevy 1/2 ton
RlB, Post a photo of your bolted on strips
1950 Chevrolet 3100 (Ol' Roy)
Otto - Try looking in his Project Journal pics. Its well documented and pictured for all to see.
~ Dan
1951 Chevy 3 window 3100
