| | | Forums66 Topics128,113 Posts1,056,614 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My 261 has a miss. I can't hear it so much under the hood but the exhaust sounds "boom, boom, etc.
I put a timing light each wire. All flashed except one. Wire 6 was inactive. I switched wires and still, the wire on 6 wouldn't flash. I replaced the points. Still, #6 wire wouldn't flash but the other 5 did.
I pulled the distributor cap. Things looked OK. I started it again and got some haphazard flashing from wire #6.
I'll see if NAPA has a new cap and rotor tomorrow.
Do these limited observations suggest anything? Thanks!! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2021 Posts: 6,895 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,895 | Plug, wire, cap, rotor are the only things it could be.
Unhless the #6 cam lobe lobe on the dizzy is wiped but I doubt that's the case.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Otto, you bring up another thought. If the disc and spring under the grease cup is not in place, the shaft could be wobbling so the points may not be opening correctly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2021 Posts: 6,895 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,895 | I thought of that but I think the miss would be a lot more random rather than only on a single cylinder.
I had a shaft wobble on the Galaxie 500 and it was completely random and would do it at different rpm and sometimes run perfectly smooth for a while. Wally's appears to be a problem isolated to #6 at all rpm.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Carbon fouled spark plug- - - -the wire can't develop enough voltage to trigger the timing light. Jerry
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'm going to reposition each wire on the distributor to the next position clockwise. Should still run since the order remains the same.
If the problem is indeed with that #6 position on the distributor, the problem will move to the #3 wire. I hope this makes since and is correct. I'll do it this afternoon. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | Pull the plugs and inspect. If they look good, switch #6 plug with another. Next step compression or leak down test.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
| | | | | Joined: Oct 2021 Posts: 6,895 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,895 | Rusted Nut, he says he's not getting any spark on #6 plug. Whether or not the cylinder has compression is irrelevant.
| | | | | Joined: Oct 2021 Posts: 6,895 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,895 | I'm going to reposition each wire on the distributor to the next position clockwise. Should still run since the order remains the same.
If the problem is indeed with that #6 position on the distributor, the problem will move to the #3 wire. I hope this makes since and is correct. I'll do it this afternoon. Before going to all of that trouble, pull out #6 plug and just replace it and see what happens.
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | I didn't see he switched plugs, just wires. If spark is good, then I'd check compression.
Geoff
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Plug 6 looks good. 0.035 gap but wet with gas.
I then moved each wire at the distributor one space clockwise but it wouldn't start. It just spun with no ignition! I thought if the rotational order was maintained, it would run.
I'm going to sleep on it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Put the wires back and switch the suspect plug to a different cylinder. 6 to 5 and 5 to 6 and see if cylinder 5 goes dead. Maybe you have a plug that looks good but is defective.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | What does a whole set of plugs cost? What did a compression test find? How about a cylinder balance test? What's the resistance of each plug wire? Sun Electric Company got it right 70 years ago- - - - -"We test- - - -not guess!" Jerry
| | | | | Joined: Aug 2010 Posts: 605 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 605 | Regarding the old Sun machines.. my high school auto shop had one, and it was considered kind of anachronistic by 1988, coming as it was from the early '70s. However its CRT oscilloscope worked great and was super handy for learning about/diagnosing ignition system issues. You could set it for vertical and it would show each cylinder top to bottom, you could easily spot a bent distributor shaft or wobbly bushings. Put it on parade and notice which cylinder had higher or lower voltage, indicating rich or lean or shorted/open wire and etc.
I kinda wish I had one, although it was so big, I'd need a separate garage for it!!
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | All this drama over an open circuited spark plug wire or a shorted plug! They should have a maximum of 1,000 ohms per inch of resistance, and a cheap ohmmeter is all that's needed to check plug wire resistance! Jerry
