0 members (),
116
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I might have used the wrong abreviation in the title, "EDP" ?? When you buy new sheet metal parts today, they often come with a black coating on them that I called EDP. My question is: For parts that won't be seen, is it OK to use these parts "as is"? I'm thinking right now about bed cross sills. Will they resist rust well enough, or should I put epoxy and paint on them before using. Also, I have a new tailgate that came with this same coating. Should I apply epoxy, sanding primer and paint, or can I skip any of that? Im curious about how tuff is the EDP? How well does it resist rust? etc.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | I don't trust whatever paint comes on aftermarket metal parts, EDP or anything else. I can't tell by looking at it to be sure if it is EDP, and I don't know what kind of prep was done before the EDP or any other paint was applied. And no, EDP will not hold up on unseen parts.
| | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | The black coating is designed to keep the steel from rusting during factory storage and shipping. Strip the black EDP and prep/prime/paint as if it were bare steel.
| | | | | Joined: Oct 2021 Posts: 6,885 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,885 | Elctro-Deposit Primer aka Electrophoretic Paint Deposition.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2019 Posts: 4,492 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,492 | Electro Deposited Paint, is the correct terminology and has gotten a bad name within the industry due to a couple of factors.
First, some manufacturers use lacquer-based coatings that are sometimes mislabeled as EDP. Lacquer is porous, allowing water absorption and subsequent rust formation beneath which leads to premature failure and must be removed. You can check by putting some lacquer thinner on a rag and wipe the black coating. If it smudges or gets on the rag, sand it all off.
Secondly, authentic EDP coatings lack UV resistance and will deteriorate over time when exposed to sunlight. Should you observe any signs of coating failure, it is essential to remove the affected layers.
However, EDP cannot be left as a final finish. Therefore, all EDP-coated parts must be top-coated with a UV-resistant finish to ensure long-term durability.
If neither of these conditions exist, then they are suitable as a base coat. Scuff it with 220-320, apply an Epoxy primer then finish as usual.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
