4 members (elhippie64, Leo, Otto Skorzeny, Gone), 60 guests, and 4 robots.
Topics128,180
Posts1,057,157
Members48,464
Socket Breaker
Socket Breaker
Hiya folks.
I was trying to do the brake shoes on my 1965 Chevrolet C10, had all the tools out, opened up the brake shoes I ordered and they were way too wide.
Hmmn, well, that sucked. So, off to the parts store with my old ones which were narrower. After some researching on the computer and some measuring with a caliper they figured out which width I needed and ordered those up.
I didn't have this problem the 2 other times I have needed brake shoes.
Anyway, I am just guessing that the wider brake shoes are for the 3/4 and 1 ton trucks for the same year? Everything else looked the same, the holes lined up and everything.
I was just wondering and thought I would ask.
Happy 'bolting.
-Woogeroo
Years ago I had both a ‘63 c10 and a c20 parts truck. Not only the difference of 6 lug and 8 lug, I could be wrong but thought the diameter was different too.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Wasn't there a heavy duty brake option that could be ordered for trailer towing, etc? That usually included drums, shoes, and backing plates about 1/2" wider than standard.
2" X 11" seems to be the most common 1/2 ton brakes front and rear.
BC
1960 C60 pasture art
Woog - A check of the 1965 Chevy Truck Data PDF under C10s shows the correct brakes to be 2" X 11" as BC mentioned. A little further checking for C20 and C30 models shows the front and rear brakes on the C20 (3/4 ton) to be 2-3/4" X 11" and the C30 (1 ton) front brakes also were 2-3/4" X 11". Sounds like you got the typical parts house mix-up on the 1st replacement set you got, or the parts counter folks selected the wrong (C20?) model truck when looking them up. Glad you got it resolved! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Socket Breaker
Socket Breaker
Okie dokie, I figured that is what happened.
I was just curious, always looking to learn new things.
Thanks everyone.
-Woog
