I don't suppose a Factory Assemble Manual exists for the 41 - 46 Chevy trucks, specifically the cab construction. (I'm working on a 1946 Chevy 3/4 ton) Looking for the flat area right at the bottom of the kick panel. I think that area is actually more part of the toe panel than the cab floor. It's the area just ahead of where the 3 bolts hold the cab floor to the frame. I will need to rebuild that area quite extensively on the passenger side. Kind of looks like a couple layers of sheet metal spot welded together to form that area. So I'm just seeing if any type of drawings are out there to help with rebuilding a rusted area.
Thank, Tom
Last edited by Gdads51; 05/23/2025 11:05 PM. Reason: edit title to become it's own thread
