3 members (46 Texaco, Otto Skorzeny, jmoore), 100 guests, and 2 robots.
Topics128,202
Posts1,057,409
Members48,471
I'm really close to getting my truck on the road, and it's time to think about tires. It's a 1946 Chevy 1/2 ton farm truck with the original drivetrain, not a LS swap. I need something that doesn't create a lot of road noise, but also doesn't break the bank — recommendations? TIA!
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
What size wheels? Both diameter and width.
15 x 5.5, best we can tell. I was hoping someome would recommend something. I have like new, period rims with tangs.
1946 Chevy
O Online: Content
The closest modern tire size to the original is 225/85 R16.
Just a quick search found a slightly smaller diameter Starfire Solarus 225/75 R16 for $93 on TireTutor.com .
1950 Chevrolet 3100 (Ol' Roy)
Those 16 inch tires would be a sloppy fit on his 15 inch rims.
Thank you Otto and Bill! He had five totally different tires when I brought him home (spare tire), and we weren't sure which to go with.
1946 Chevy
O Online: Content
That post wasn't made when I first responded. I assumed he had original 16" dia rims.
Make sure they're 15"
U
U Offline
I have original 16inch wheels and bought these from a local tire shop. $150 a tire which was affordable for me. I'm sure you can find 15inch tires at a good price.
~ John in Utah
Here We Go
Follow in his DITY Bay
Insomniac
Insomniac
If you are not going to haul heavy loads with it, you can use passenger car tires. I bought Kumho Solus TA11 tires. I chose the skinniest ones they sell for easier steering. Max load is 1,600# @ 36 PSI.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thank you Utah York and Gord&Fran! I didn't know about thinner tires/easier steering. That would for sure be helpful!
1946 Chevy
O Online: Content
Also try to find the largest diameter tire that will fit without being too wide. The original tires would have been about 30"-31" in diameter.
The larger the diameter of the tire, the faster you can drive at lower engine rpm.
