4 members (52Carl, Steveoreno, Samantha, 1 invisible), 102 guests, and 3 robots.
Topics128,211
Posts1,057,469
Members48,473
I'm really close to getting my truck on the road, and it's time to think about tires. It's a 1946 Chevy 1/2 ton farm truck with the original drivetrain, not a LS swap. I need something that doesn't create a lot of road noise, but also doesn't break the bank — recommendations? TIA!
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
What size wheels? Both diameter and width.
15 x 5.5, best we can tell. I was hoping someome would recommend something. I have like new, period rims with tangs.
1946 Chevy
The closest modern tire size to the original is 225/85 R16.
Just a quick search found a slightly smaller diameter Starfire Solarus 225/75 R16 for $93 on TireTutor.com .
1950 Chevrolet 3100 (Ol' Roy)
Those 16 inch tires would be a sloppy fit on his 15 inch rims.
Thank you Otto and Bill! He had five totally different tires when I brought him home (spare tire), and we weren't sure which to go with.
1946 Chevy
That post wasn't made when I first responded. I assumed he had original 16" dia rims.
Make sure they're 15"
U
U Offline
I have original 16inch wheels and bought these from a local tire shop. $150 a tire which was affordable for me. I'm sure you can find 15inch tires at a good price.
~ John in Utah
Here We Go
Follow in his DITY Bay
Insomniac
Insomniac
If you are not going to haul heavy loads with it, you can use passenger car tires. I bought Kumho Solus TA11 tires. I chose the skinniest ones they sell for easier steering. Max load is 1,600# @ 36 PSI.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thank you Utah York and Gord&Fran! I didn't know about thinner tires/easier steering. That would for sure be helpful!
1946 Chevy
Also try to find the largest diameter tire that will fit without being too wide. The original tires would have been about 30"-31" in diameter.
The larger the diameter of the tire, the faster you can drive at lower engine rpm.
