0 members (),
142
Mod | | | Forums66 Topics128,132 Posts1,056,730 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | I just purchased a 1941 Chevy truck, serial number 21DR-D 3770 Engine number is ABCA 625285 What do I have? Is it or was military?
Last edited by Randy latvala; 04/25/2025 6:00 AM. Reason: cleaned up misspellings no Z in engine number
| | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | My plan is to replace the 6 cylinder engine with a sbc (355) that I already have! I need info on motor mounting and adapting the sbc to the 1951 bell housing! | | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | The truck came with loose front fenders and radiator! There is no grill or hood. The box sitting on the rear frame may be a later model box with no planking or fenders! I will measure the inside width to see if it compares to another year that members here may have. Is the original engine of any decent value! I didn't even try to start it but I'm sure I could get it to go! Someone has removed the intake/exhaust manifolds as well as the carburetor!
Last edited by Gdads51; 04/24/2025 11:17 PM. Reason: cleaned up spelling and other typos
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Built in Janesville WI, April 1946 3/4T, 2770th off the line. No problem advising motor mounts , etc. You are a ways away from that. I think the engine is a 1950 Flint 235.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Can't price a motor from a forum post. Impossible to get close. Depends on many things. Geographic location, (probably won't be shipped), if it runs, how good it runs, how well it tests compression, etc. completeness and what a willing seller and a willing buyer end up agreeing on. ~ $100-$900
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | I'm surprised it's a 46. Not unusual for the guy not knowing with no real history on it if the engine was changed to a 235. That constitutes a drop in swap doesn't it? | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Welcome to Stovebolt Randy!  "bartamos" decoded your trucks serial# perfectly! Your given engine serial number is a bit too long for any decoding I tried to do. A 1950 engine for a 3600 truck would have had 4 letters at the beginning of the sequence. Yours has 5 which doesn't match any known codes that I can find. If you want to pursue further engine ID info, I suggest you post an new thread in the Engine Shop where it will find more direct help. I would also suggest you add some pictures of the stamped serial number and block/head casting codes (raised alpha/numeric characters) you can find as those will go a long way in confirming what you have. One other suggestion before we continue your conversation. Please read our Welcome - and now where do you go?? post before creating more posts. It will help you understand our site format and better navigate and get more help as you dig into your project. Once again, Welcome!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | My plan is to replace the 6 cylinder engine with a sbc (355) that I already have! I need info on motor mounting and adapting the sbc to the 1951 bell housing! Randy - Your topic here may be better asked in our HiPo Shop, depending on what other modifications you may have planned for your truck.
| | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | The box on it is 50 inches inside with 80 inch side rails | | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Your pickup box appears to be from an AD series 1947-1955.1 1/2 ton, which measures 50 inches wide (inside) by 78 inches long (inside). Does the tailgate have "CHEVROLET" embossed on it. An earlier tailgate would be plain (no embossed logo.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | Yes it does have chevrolet embossed in it Are fenders for this available? How do the fenders mount on the side of the box? This truck has all 8 hole wheels and I have found some dually rims onarketplace one thought would be to make a 46 dually! If I could find some extra depth fenders or fabricate fenders extensions betwern the box and fenders mounts!
| | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | One of yhe tires c that came with it is a 7.50'16 which seems to be more of a fit to a 1 ton or 3/4 ton! | | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | I will give that engine away not knowing if anyone needs or wants it! | | | | | Joined: Apr 2025 Posts: 30 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 30 | 3/4 brings a whole different world of problems The front part is the same as a 3100 so cab forward body parts are the same and mostly can be found The bed is longer so the running boards are different and a bit harder to come by if You don’t have them. First challenge is do you have brakes and all the break parts? Unfortunately they are made of unobtanium. Then we move on to the differential unless you are extremely lucky it’s a 4:56, the 4:10 gears are also not to be found. So probably need to get a different rear axil. Once you have a rolling frame with brakes then you can move on to the rest of the drive train. 3600 box is 88 inches has 3 stake pockets, that tire size would be a 3600 single rear More than once I have thought about just getting a 3100 rolling frame to put my 3600 front parts on. And I’m starting with a complete truck minus the brakes, with a cab with very little rust
Stop take an inventory of what you have, then decide what you want to end up with. Keep in mind that the wheel base and over all size is closer to something like a S10 than a 2500 | | | | | Joined: Nov 2021 Posts: 1,393 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,393 | I am currently working on a '50 3600 that includes a SBC (383), NV3500 manual transmission, and '86 vintage 14-bolt Chevy rear axle (4.10). As tired51chevy noted the 3/4 ton brings a lot of differences from the more typical 1/2 ton version. You can review my Project Journal to get an idea what I have done and feel free to contact me if you have any questions about my build. | | | | | Joined: Apr 2025 Posts: 30 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 30 | Now the SBC part isn’t really much different than doing it on a 3100 WICruiser we have the same taste in paint that looks like the same blue I used | | | | | Joined: Apr 2025 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 11 | Thank you iif i had another frame now i would consider moving the cab to it! Those days are gone i had a nice collection of old cars and trucks 2 women and two houses ago! Where fo i find your project jourmal? My question of the day is glass? Are these guys using Alexander with geometry rubber? | | | | | Joined: Apr 2025 Posts: 30 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 30 | Click on the blue link that says Follow in project journals In his post
Glass isn’t really a problem new is available, and yes it’s held in by rubber The cab isn’t model specific but they are year specific for some stuff like windshield There is a break some where 2 pice to the one piece your’s should be a 2 piece Door glass depends on the year of the doors vent window or no vent widow.
The parts vendor web sites will be of some help there There should be a list somewhere | | | | | Joined: Nov 2000 Posts: 1,970 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,970 | ABCA 625285 => B = 1941, C = 3600 (3/4-ton) or 3800 (1-ton), second A = Flint, MI engine plant. The 4 letters together: A_C_ was used for 3600/3800 engines for several years.
Professional Novice
