| | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | 1952 1/2 ton. Battery box is under passenger floor. Has an aftermarket carpet kit. The kit did not come with a "cut out" for the battery box. Carpet goes over floor sill down the door recess and snaps to secure.
Not a fan of this. What has been used by you guys? | | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Unfortunately that is common. Mine is the same way. Absolute PIA to take trim screws out and have them catch the carpet threading when reinstalling.
I did install the battery box that drops down to get better access. It still doesn’t allow for battery removal. I am going to look at modifying the front panel so it will open in order to remove the battery an install a battery.
You could always have the carpeting altered by an upholstery shop. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | My carpet is not pinned down via trim strips. It just sits there. If I need to access the battery, I just lift the carpet and there we go.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | My carpet has one screw in the carpet. Remove screw and lay back carpet. Easy to do. Don't need to fool with the battery that often. | | | | | Joined: Sep 2013 Posts: 1,364 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,364 | My original rubber style floor covering had no battery access either. I've just accepted the 3 minutes required to use a battery powered drill with a screw driver bit chucked up to zip out 4 screws, remove the metal strip securing the edge of he floor mat and rolling said mat out of the way to open the battery box. Since it's usually only a once or twice a year deal, no problem. I do have a battery charger plug permantently installed that tucks neatly into the bottom of the battery box, just reach under the truck and pull it out to plug in a maintainer/trickle charger that I sometimes leave plugged up if not driving the truck for a spell.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
