6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#1575410 04/18/2025 10:18 PM
I’ve been driving it a couple times a week now and have a good bit of play in the steering wheel. What is a way to take some of that out.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Depends on where the problem(s) is (are).
Could be:
1. Steering gear box mounting bolts loose (not very likely)
2. Steering gears in the steering box worn out
3. The worm gear bearing adjustment
4. The sector gear lash adjustment
5. The Pitman arm sloppy on the Pitman shaft (not very likely)
6. Ball or socket on either end of the drag link worn or out of adjustment
7. Ball or socket on either end of the tie rod worn out or out of adjustment
Start by getting someone to sit in the driver's seat and rock the steering wheel back and forth a little. While that is going on crawl under and look for one of these pieces moving while its connecting piece doesn't.
And it'll never steer as precisely as a modern car.
Moderator, Electrical Bay
Also once you figure out what is causing the play (Bill's list is a very good one) please make sure your caster shims (bottom of the springs) are in place and giving you the right adjustment. It will not affect play in the wheel but the proper caster will prevent your truck from wandering around like a drunk goat.
~ Jon
7
7 Offline
One thing to add to Bill's list is kingpins and bushings. If the slop in the wheel is a little less while the truck is sitting still, the kingpins and bushings are suspect.
It may take two people but looking carefully at the drag link while moving the steering wheel will help work through Bill's list.
Starting with the wheels straight ahead move the steering wheel back and forth and watch for movement at the drag link end of the pitman arm. That will give you a clue about the steering gear parts.
Continue movement of the steering wheel back and forth and watch the drag link movement compared to the pitman arm.
Then move on to the other end of the drag link where it connects to the spindle and finally to the tie rod end connection to the spindle.
There will be a little movement everywhere but you should be able to tell where the majority of it is as a starting point for further diagnostics and repairs.
1949/50 3600 Project
Follow in Project Journals
Jack the front front up to get the tires off the ground.
Turn the steering full right, then back full left.
Did you feel a tight spot dead center of the gear box?
Yes you did, start checking the rest of the steering and suspension.
No you did not, pull the draglink off the pitman arm so you can adjust the steering box without the rest of the steering moving.
See here for proper adjusting, https://chevy.oldcarmanualproject.com/booklets/5220mts01.htm All gear boxes adjust the same way.
