1 members (Bill Hanlon), 181 guests, and 4 robots.
Topics128,108
Posts1,056,239
Members48,437
#1575180 04/15/2025 11:36 PM
I replaced my Arvin heater switch and I now have continuity through the switch. I applied about 10 volts and nothing. The ground wire got pretty warm. I think it is the original fan. Where do I get a replacement fan motor for it? I am switching the 1946 1/2 ton truck to a 12v system. I included the type of heater I have. TIA
Hank
Mine is an even older Arvin. But I found a perfect fit at grainger. Check all the dimensions online, but I think they used that same motor forever. Probably 12v or 6v available
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1575362 04/18/2025 12:13 PM
Thanks 37 GC I will take it out this weekend and measure the mount holes and shaft. I would rather go with a 12 volt. I plane on taking the core to a radiator next week to get it checked out.
Moderator, Electrical Bay
When you take it out and measure it, please look at the Freebies section of the Swap Meet. There is a 3 speed motor I've offered there free for the cost of shipping. We can see if it will work for you once we know the dimensions, etc of yours.
~ Jon
Copy that Jon G. I will take a look and see.
Moderated by  ndkid275, Phak1
