| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 190 'Bolter | | 'Bolter Joined: May 2011 Posts: 190 | Rebuilt a distributor for a 1954 235 motor. It works great, the problem is I'm missing the screw on cap for the grease cup. Before I do a lot of searching, I was wondering if anyone knows if these are sold new or is used the only option. If only used is it, I will keep my eye open for one at a swap meet I guess. Appreciate any ones comments!
Tom | | | | | Joined: Feb 2004 Posts: 29,807 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,807 | Here is a complete unit that will upgrade the original. It's made of brass, and will not only improve the appearance, it won't rust like the original steel one. Use the spring and plastic thrust washer from the original assembly. www.ebay.com/itm/204958410029Jerry
| | | | | Joined: Feb 2005 Posts: 1,651 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,651 | Oooo - That's a pretty one! I like it.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
