4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#1575279 04/17/2025 12:53 PM
Any suggestions?  I applied some sound deadening matts to the floor and half way up the firewall of my 53 3100.  It didn't make a real noticeable difference.  Next I was thinking the doors.  Do you apply the sound deadener to the outside door skin or the inside door skin/panel?  Where else besides doors?  Will it really make any difference?  Truck is pretty much original.
Dave from Northern Kentucky
My 54 3100
AD Addict & Tinkerer
I applied it to the outer skin and it made a huge difference. Not easy but totally worth it! Make sure you cover any holes in the firewall as that will help stop engine noise coming into the cab.
Phil
Project Journals
Stovebolt Gallery Forum
Doors and ceiling will make the biggest difference in eliminating the tin can effect.
1950 Chevrolet 3100 (Ol' Roy)
My 54 3100
Moderator, Electrical Bay
Dave there is some science involved here. Hoping not to be boring but the way this stuff works is by reflecting sound waves (a form of kinetic energy) back toward the source (the metal panels). By doing that, sound waves are transformed into heat waves and in that form will dissipate into the foam (not enough to notice heat increasing but that is what actually is happening). Here is an explanation of sorts.
I should add decibels are on a logarithmic scale so only a reduction by 3 or 4 decibels inside your cab will be noticeable. A reduction of 10 db might be the difference between hearing a police siren going by you and somebody talking. On the db scale a difference in 40 db to 20 db isn't a reduction by half. 40 db is 100 times louder than 20 db. From there the weeds I'm wandering in can get trickier, but for now let's just say a good 1/8" foam covered with thick foil is going to be fine. Even heavy duty household foil might be okay if covered by something to protect it.
What I did was to use 1/8" thick self-adhesive neoprene sponge foam (something like this: https://tinyurl.com/3pd9ncn4) and cover that with foil thermal barrier material (which I had coated with double sided adhesive). It was the same stuff we stapled to the joists in our attic which made a great difference in heat transfer reduction and reduction of our utility bill. As you would expect thicker is better as it gives the sound waves more to disappear into. Most of the folks I see saying the stuff didn't work have stuff that wasn't made correctly. The metallic layer is what bounces the sound back toward the source. Bottom line is if you can get foam like this, radiant barrier foil like this and double sided adhesive you can reduce the noise level notably. But please note: any foam that works well as a sound barrier is going to be absorbent...it must be. The air bubbles are what further break down sound wave energy. A solid or closed cell foam will transfer sound waves rather than bust them up for you. And you may not want absorptive foam inside your doors...it will get wet easier than it will dry.
One other thing...please look between your front cab mount and your frame. A lot of our trucks have cabs that are sitting straight on top of the frame at the front mounts...the pads have settled to the point where there is no air space any longer. If you can't see space between your cab mount and your frame, then you can loosen the nut, jack it up a tiny bit and slip some shower liner pieces cut in sort of a U shape so you won't have to remove the bolt (usually about 1.5mm thick) in there until you get enough to move it upward. Gently...this will alter the adjustment of your front end if you move it upward too much and it might be a good idea to loosen the bolts which hold your radiator support (which also holds your front sheet metal). You are just going for 1mm or 2mm of space in there. If your cab is sitting on your frame, a lot of noise will be telegraphed through there. And I do mean a lot. Like somebody running a vibrating sander on the bottom of an empty 55 gallon drum or something. Good luck!
~ Jon
What Jon said. Also, the weight of the material applied has something to do with reducing vibration. Even a blob of tar in the middle of a panel will change it's natural frequency and reduce the sound generated somewhat, preventing the panel from drumming. That being said, the heavier the material used will make it perform better to reduce sound. I used a stick-on neoprene foam without a foil layer, and while I don't have a comparison, it's reasonably quiet. I covered the inside of the outer door skin, the entire roof, behind the gas tank. Getting it in the doors was an issue, as I almost got my arm stuck and was thinking I would have to call the Fire Department to extract me. eek
Firewall.
Toeboard.
Floorboard.
Cab corners.
Underside of the cowl. A lot solar heat radiates through the cowl.
Inside of the outer door skins.
Ceiling. I use rubber compound cement on the ceiling to make for better adhesion of the stick-on roof flashing that I use.
Makes a very noticeable difference. You don't have to yell at the Ole Lady for her to hear you, but you still won't be able to hear her mumble to you.
dgrinnan #1575366 04/18/2025 12:28 PM
Carl, much like you, if I could reach it, I used deadning material. After that I still used the jute padding and carpet.
I love it now!
Chris
Moderated by  ndkid275, Phak1
