| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bed Wood Tech Tip info from a Mar-K Tech Tip that seems to has disappeared with Mar-K:
Apply on unfinished bed wood:
Three coats of POR-15 Rust Preventative Paint as a seal coat and three coats of Behr gloss black enamel.
The finish has dulled slightly, but is still very glossy and has sealed well.
The finish has lasted much better than the first test series (that post/report has also disappeared?) in which they used Behr primer and top-coated with the same Behr gloss black enamel.
Even though POR-15 Rust Preventative Paint is not specified for wood by the manufacturer, it appears to be an effective primer if it is coated with a quality topcoat paint.
If you plan to paint your bedwood, this finish system should be considered as it is very durable and easy to apply. | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Tim, I don't think that was actually ever a tech tip here on Stovebolt, but possibly there was a link to Mar-K's website, which is now defunct, since they've gone out of business.
But thanks for bringing that up and posting it here.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Did you brush this on? Also, did you paint the metal strips, and bolt heads too? I assume that you painted the wood before the bed was assembled, is that corrrct?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Bed wood should be painted before assembly, so you can get all 6 sides of each board fully coated with whatever you use. If possible, drill the mounting holes in the outer boards that go under the angle strips and get the holes coated also. Metal strips should also be painted - they were black enamel originally, with the angle strip painted body color. Bolts were originally cadmium or zinc plated.
