11 members (Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
98
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | I live in a land where plastic rusts. Doing the valve seals debacle I had to pull the headers off. I noticed the bolts were rusted. Okay go to jungle store and order SS header bolts. Go to install headers and new bolts. Grab 3/8 socket... what the ?? Does not fit. Try other sockets/wrenches, Nope. Grab 10mm socket and a perfe ct fit. Why machine a 3/8 thread and use a 10mm head? Bet you can guess where the bolts were manufactured. | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | ARP does the opposite. They put american sized heads on metric threaded bolts. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | ARP and others have the combo Fibonachu mentions because folks that are stuck with metric threads want to use their SAE tools. An accommodation for USA customers. I don't know who is accommodated with the combo you have. I hope you did not use a cordless or electric or pneumatic driver in case the whole fastener was metric. A SS bolt will be hard like a tap. Anyway if that was not spelled out by vendor, I would have sent them back. What vendor was this? Part number? Don't know what "jungle store" means.
Last edited by bartamos; 04/15/2025 10:40 PM. Reason: relocated "extra strange thoughts" paragraph.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | My extra strange thoughts. Sense the internet and AI does not show any SAE thread/Metric head bolts..........Header bolts are usually 12 point, maybe you tried a 3/8 6 point socket on a 12 pt head, then used a 10mm. 3/8= .375, (10mm= .393) and the 10mm 6 pt slipped over the 12 pt, jammed up, torqued and voila.... or as I said, the whole bolt is metric and you "rethreaded" the head.... or the whole bolt is metric and you have a motor with metric threads. I asked for vendor and PN so we can please see this weird bolt. The 3/8 SAE and a 10mm thread have near the same pitch. So this adds to some concerning possibilities.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | Jungle store = Amazon. No 12 pts. I specifically looked for regulator bolt heads. Reason is, I can't get a socket on several of the bolts. Header tube is very close to the bolts hole, had to use open ended wrench. After finding 10mm head, I checked threads with thread a sizer. They are 3/8 threads.
SS fastners are brittle, hence never sneeze, and tighten frequently | | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | Vender is JBKE part no. Is LYH-AD224EX
On Amazon it states 3/8 Thread, nothing about 10mm head. The bolts went in just using fingers and hand holding socket where I could. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I see what you mean, very deceptive. The vendor failed to tell amazon it is a metric head, Just says 6 pt head. A search comes up as available at Amazon, Sierra Leone and Jamaica. That's why the internet does not know about this bad choice. You did the right things, you didn't ever suspect this kind of bolt. All is well. Thanks for the info. I wrote to Amazon to tell them there is missing info purposely left off by their vendor who is dumping a manufacturing mistake bolt on them. Once Amazon terminates them, folks will have to buy from Sierra Leone or Jamaica
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | Just little things like can...well just shake your head. I wrote this down in my truck notebook. At least I tested sockets first.
They do look better with ceramic coated headers. Typical stuff from chinaco. | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | They do look better with ceramic coated headers. Typical stuff from chinaco.  | | | | | Joined: Apr 2025 Posts: 30 'Bolter | | 'Bolter Joined: Apr 2025 Posts: 30 | That’s why I order fasteners most of the time from McMaster Unless it’s for a special purpose like rod, main or head bolts | | | | | Joined: Mar 2007 Posts: 3,440 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,440 | We have a vendor here, Automotive Fasteners, who typically have exactly what I need in stock. There are some cheaper made fasteners available, you just need to be careful when ordering.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
