4 members (Greg '46, Stewart2, Philipj, BillyDon), 64 guests, and 8 robots.
Topics128,180
Posts1,057,150
Members48,464
Did a search, but… My '51 GMC , ONE TON, never has had rear shock absorbers. There are original lower shock mounts welded to the rear axle housing but NO an upper shock mounts on the frame rails.
I would like to put the upper mounts in but everything available seems to be for half ton trucks .
Is anyone in the same boat? Thanks
Looking at the 1951 Chevy vehicle info kit, the 3800 rear shocks were RPO not standard equipment. I'd assume that GMC's were the same. The FAM shows upper brackets rivet to the inboard of the frame on 3800's with PN 3705695 (LH) and 3795696 (RH) with a lower mount welded to the axle tube. Those same upper mounts were used on 4000, 5000, and 6000 series Chevys. So maybe you could find a pair of upper mounts on a bigger truck.
klhansen , Thanks for the info. I will attempt to locate a couple of those. Great info for all of us! cool
GMC Master Parts Book lists part number for your '51 250 series truck's rear shocks as part number 5513639 with an asterisk that says "Determine if option required". Same book shows Frame Shock Absorber Bracket part number 3693689 with the same asterisk.
Looks like an option to me.
O Online: Content
Are you expecting an improvement in the ride by adding them?
1950 Chevrolet 3100 (Ol' Roy)
Only some minor improvement in the rebound portion. I don't think anything can be done on the compression when you have more leaf springs than can be counted!!!
O Online: Content
That's what I was thinking.
