1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#15746 05/17/2003 3:40 PM
I am looking over one of these add on oil filter canisters and have to wonder if they are of any value. The return oil outlet hole is only about 1/16 " diameter. It seems like 98% of the engine oil is still going to bypass the filter and you're still left with a can full of dirty oil at oil change time. Any comments?
#15747 05/17/2003 5:57 PM
Those add on canister filters are not anything like the modern full flow filters. They are better than nothing and if I can remeber correctly the owners manuals in the some of older cars states that the oil should be changed every 1000 miles. We drive our cars alot more miles today than they did back then and I quess those filters did the job. Use a good oil and change a few times a year depending on how much you plan to drive
#15748 05/19/2003 7:39 PM
They are that way so that it only lets 10% of the oil bypass the motor, otherwise you would have oil pressure problems.
Paint & Body Shop moderator
