Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (VEW, mo2cyl, 2-Ton, Otto Skorzeny, Deegs53, 2 invisible), 610 guests, and 1 robot.
Topics126,781
Posts1,039,298
Members48,100
Most Online2,175
Jul 21st, 2025
Moderated
Moderated
My 1953 3100 has a single barrel Rochester carburetor and an oil bath air filter. I’d like to go to a paper filter option. I can only find air filters with a 2 5/8 inch neck diameter. My carburetor is 2 1/4 inches in diameter. Does anyone have any good suggestions? Thanks in advance.
Red3100 - 1st off, Welcome to Stovebolt! thumbs_up Your topic best fits in our Engine Shop, so it's been moved there for further conversation and help. Will catch up with you soon as I think I might have a suggestion. wink
PS - I sent you an email.
~ Dan
1951 Chevy 3 window 3100
O Online: Content
Are you talking about the entire air cleaner assembly, or the paper element itself?
This filter assembly was on my truck when I got it. It originally had an oil impregnated bronze or copper mesh filter element. IThe carburetor barrel is 2 1/4" outside diameter.
I found a closeout deal on these LuberFiner filters for $5 each. The NAPA ones are about $25 each.
Here are the paper ones that fit it.
NAPA Gold 2375 or 2373
Baldwin PA678
Hastings AF54
Carquest CA77
LuberFiner AF213
Fleetguard AF843
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Since he talks about the carb diameter, he must be having issues with the filter housing fitment to the carb. When I get home, I will look at my setup which is paper related.
Craig
Red3100 - If it might interest you, perhaps you could look at this Stovebolt Legacy Tech Tip on converting an oil bath air filter??? You could still use the oil bath filter housing that fits your carb and looks stock, and do away with the oil bath portion. If you search through the Engine Shop forum, you can find other variations on this conversion theme that may work better for you.
~ Dan
O Online: Content
www.ClassicParts.com
They list an air cleaner assembly similar to the one I pictured above for $90 (part # 86-603). Stupidly they don't list the diameter of the mounting area, only that it fits Carter YF carburetors from 1937 - 1959. My truck is a 1950 so it should be the same size - 2 1/4", which is the same as your Rochester.
They want $15 plus shipping for replacement elements.
Use a small spool of PVC plastic drain pipe to make a spacer between the filter housing and the carburetor air horn. If the diameter isn't quite right, the PVC plastic can be shaped easily with a drum sander in a hand drill motor or a drill press. There's no need to reinvent the wheel because of a minor diameter difference.
Agree with Jerry, but you should be able to find a 2-1/4” filter assembly.
Here’s mine which is 2-1/4”. And don't ask why my fuel line is soooo bent. Next project......
Craig
What happened to the leaking gas stains on your carb Craig?
Insomniac
Insomniac
I bought an air filter designed for a 4 barrel carb. To fit it to the much smaller Rochester, I sacrificed a spare headlight bucket to make a spacer/adapter. Of course, I needed a longer stud to attach the air cleaner to the carb.
Obviously, this won't work if you need the clamp on style air cleaner.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
If you have a John Deee around you , check out one of these grass deflectors used on the bigger mowers,
https://www.greenpartstore.com/john-deere-deflector-m163053.html
They fit small carb openings when you cut the top off, I had a couple on my truck for a while, painted gold to match the old Moroso Racing velocity stacks from the 80's. They are pretty heavy duty and will take welding and cutting pretty easy.
huh?
Craig
Sorry Craig. Was just a backhanded compliment to your nice clean Rochester which are usually stained with gas leaking from the warped joint between the carb's body and the air horn.
O Online: Content
That picture was taken prior to use, just after installation.
It's all good Bill. Pic from yesterday. Carb rebuilt 2 years (2,800 miles) ago. Still trying to find Red3100 a air cleaner assembly like Otto's and mine.
Craig
O Online: Content
That filter would probably work on my 46 but with any oil/air filter swap do u need to make any changes to the carb settings?
1946 Chevy Truck
"Tales from a weekend mechanic"
Follow in the DITY
O Online: Content
No, as long as the carb is getting enough air. If it doesn't, your engine will run rich. My truck, with the filter pictured, gets around 12-13 mpg which is what others get with the stock mesh filter.
Yup! I'm averaging 14 mpg with the filter shown above and a light load.
Craig
Great, thanks. I’m not necessarily good with carb adjustments
1946 Chevy Truck
Follow in the DITY
1 Offline
I may be reopening a can of worms here but my reaction to the paper element conversion issue is: "Why bother." It can be a lot of work or at least head scratching looking for a solution for little benefit. Consider that the expensive cars (think Cadillac) were the last to adopt paper elements. And medium and heavy-duty trucks still had oil-bath cleaners into the seventies. IMHO the major issue with oil-bath air cleaners is maintenance costs. It's far less time consuming to swap out a paper filter than clean an oil bath. For the amount of driving most of these trucks get a minor improvement in air quality just isn't an issue.
1951 3800 1-ton
In the DITY Gallery
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.052s Queries: 16 (0.048s) Memory: 0.6989 MB (Peak: 0.8486 MB) Data Comp: Zlib Server Time: 2025-09-22 21:46:52 UTC
Valid HTML 5 and Valid CSS
