9 members (Gdads51, Rustnut, 3800GUY, KEVINSKI, Southerntruck, klhansen, dt235sd, Otto Skorzeny, Hotrod Lincoln), 69 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
#1574448 04/05/2025 9:26 PM
Hey Guys,
Looking for advice on how to determine the seat belt length I need for my 1953 3100. I plan to do lap belts only at this point as I am not in the process of a overhaul and just trying to replace the belts I took out of the truck. The belts I removed were installed via Rube Goldberg Instructions (attached to my seat frame) and were ridiculously long. I think the 60-inch belt will suffice but figured I would ask before hitting the Buy Now button.
Thanks for any advice
Deegs
1953 3100
What ever you think, they will need to be longer. I estimated on my 66, eyeballed from the attachment point, etc, and the center lap belt is barely long enough for my skinny kid with the seat all the way back.
Doing it again I would take a piece of rope and tape.it to a mounting point, run it all the way around with the seat forward for the longest it needs to be.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Ferris,
Thanks, I think that is a good idea and will try it. Better than guessing based on the length of the old seat belts that were not made for this truck and were too long.
Deegs
1953 3100
Ferris, I did the same thing! I measured and then moved my belt placement, now the clasp is harder for my kids to buckle.
Chris
Moderated by  ndkid275, Phak1
