3 members (tesa, Youngin' Tut 59, 1 invisible), 108 guests, and 1 robot.
Topics128,088
Posts1,056,110
Members48,434
#1574197 04/02/2025 6:52 PM
Hopefully soon I can begin repairing the bad floor @ collapsed front corner. Any advice is appreciated. I plan to weld it myself and wondering if I should remove the fuel tank?
I assume the truck itself should be well grounded otherwise?
Thanks.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Just from a safety standpoint, I would remove the gas tank unless you can confirm that it's well sealed and there are no fumes that might ignite.
As far as grounding, I don''t believe you really need to do that independently of the ground cable to the welder. You truck (if basically stock) doesn't have any electronics that might be affected by welding.
Read through MPandC's Tech tip here for some good tips on mig welding sheet metal.
Take the bomb out from behind where the seat used to be.
