1 members (Rich'sToys),
90
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 94 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 94 | I made my way to the kingpins and made an attempt at knocking them out. No way no how, they're stuck in the axle. Aside from a big press and maybe some additional heat, any help?
Also, will replacement pins need to be reamed to fit? I've read yes and no.
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
| | | | | Joined: May 2015 Posts: 11,082 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,082 | How was your axle supported when you tried to drive them out? If they were hanging on the springs, there's no way they're going to come out. Put a STURDY jack stand under the axle as close as you can get to the king pin and use the largest BFH you have. I would also apply some penetrating oil first, and maybe some mild heat (maybe up to 300F with a propane torch.) I'm assuming you did remove the lock pins first. From what i understand, 3/4 ton spindle bushings need to be reamed to fit the king pins after installation in the spindles. 1/2 ton spindle bushings drop in and don't need to be reamed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2018 Posts: 94 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 94 | Truck (frame only in reality, front suspension is the last to come off) is on a lift so I lowered the axle onto a set of jack stands and the BFH, nothing. About a week of Kroil soaking after my first attempt, still nothing. I think I heard them laugh at me. I did try and heat one side, no idea of the temp but the grease was boiling. Still nothing.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I attempted the same on a donor axle from a 1 ton I had it in the press at 20 tons and it didn’t move I gave up on it and moved onto other projects I kept the original sloppy king pin axle in the truck for now Hoping to find a solution one day The plan was to rebuild the donor and swap it into the work truck
Thinking maybe pushing out the pin with an oxygen lance in the future. But that might be too hot for the axle
Please post any solutions as I’m interested too -s | | | | | Joined: Feb 2004 Posts: 29,822 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,822 | I use a 20 ton bottle jack and a fixture I made to support the top of the spindle. Push the kingpin out the top. Been doing it for quite some time that way. Send me a PM and I'll send you a sketch. Yes, the new bushings need to be honed or reamed to fit the kingpins. Jerry
| | | | | Joined: Mar 2020 Posts: 261 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 261 | Concidentally I just knocked them out of my 49 3600 this weekend (with a 53 axle under it as it turns out).
I have a ten ton press but because the thing is so awkward I just tried my u-joint press and a slight touch of the oxy acetylene, I'm not talking colour change here just warm it up - and they started moving.
I haven't reinstalled mine yet, just cleaned and painted everything.
Yes the bushings need to be reamed I used an adjustable reamer; I do have a lathe to make alignment bushings but the one it came with worked great. Can only take a very small amount of metal off at a time which is really a good thing, but it takes a "few minutes"
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver OT Vehicles: 1925 Hudson Brougham Super Six 1950 Chevrolet Styline (Parts) 1952 Canuck Pontiac Sedan Delivery (Well Underway) 1973 F250 4x4 Highboy 1977 F250 4x4 Lowboy
| | | | | Joined: Feb 2025 Posts: 88 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 88 | I use a 20 ton bottle jack and a fixture I made to support the top of the spindle. Push the kingpin out the top. Been doing it for quite some time that way. Send me a PM and I'll send you a sketch. Yes, the new bushings need to be honed or reamed to fit the kingpins. Jerry Hey Jerry. Alot of the things I see you say "PM me" for can usually help other folks. I'm not big on pm'ing. No particular reason. I don't like to talk on the phone either lol Your sketch sounds interesting though. Could you just post it up? | | | | | Joined: Jun 2018 Posts: 94 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 94 | Was thinking about the comments 2ManyTrucks made. I wanted to change them not because they are sloppy, in fact one of them is the opposite.
So what I have is one side has no play in any direction. No movement vertically and no play in the bushings.
The other side spins nice, no play in the bushings but a small amount of play vertically as if the spindle wasn't shimmed right.
kind of just plannning on letting it ride for now. When it becomes an issue I'll deal with it. Thanks for all the comments!
