1 members (Hotrod Lincoln), 112 guests, and 2 robots.
Topics128,142
Posts1,056,491
Members48,442
I have a 1941, Model AK, Chevy Pickup that I am trying to mock up a complete exhaust kit on. Can anyone tell me where spring, 368244 goes? Also, where and how the rear tailpipe hanger mounts? Any pictures or information would be appreciated.
I have a 1941 AL and can get pictures this weekend it should be similar.
1941 Chevrolet AL 3/4 Ton previous Portsmouth Ohio Fire Dept
1959 Chevrolet 3100
1966 Chevrolet C10 "Sunoco Truck"
1986 Chevrolet C20 Crew Cab 454 lowered 6"
1991 Chevrolet R1500 Suburban LS 6.0/4l80e swap lowered on Qa1 coilers
1994 Chevrolet c1500 lowered 2/4 on 17x11 Billets
2000 Chevrolet Silverado 1500 full custom on air bags.
Thank you…
I purchased this complete exhaust system from a vendor and it was supposed to fit like the original!!
Factory exhaust pipes on passenger cars had a clip welded on the top side (on the section of pipe that was flattened) and then a short spring from the clip to a corresponding frame hole above. In the 1942 Master Parts List, 368244 is listed as “Spring, exh. pipe clip” all coml. I can only assume the truck had the same setup with a different length spring.
Rexville48's info looks to be spot on. wink A scan through multiple Chevy Master Parts books provided the below pics. The exhaust diagram shows the "flattened" section of the pipe before the muffler where the "welded clip" was attached to the pipe and the spring connected to that and nearby frame hole. The diagram also provides details on the tail pipe hanger. The model application designation "all coml." includes the AK model so the spring definitely applies. According to the parts books, the dimensions of the spring are "5/8 O.D. - 26 coils - two hook ends". GM# 368244 is also used as the brake & clutch pedal return springs that fits 1934-1946 Chevrolet & GMC trucks. Overall Length is approximately 3-3/8".
Hope this helps you out. smile
~ Dan
1951 Chevy 3 window 3100
