3 members (Waveski, Otto Skorzeny, chuck2213), 70 guests, and 4 robots.
Topics128,021
Posts1,055,357
Members48,420
#15739 02/01/2004 3:44 PM
Junior Member
Junior Member
When installing a cam during a rebuild, can the cam be installed incorrectly if the timing marks are dead on? I was thinking it can (TDC compression or TDC exhaust).
#15740 02/01/2004 10:18 PM
Junior Member
Junior Member
I do not know what type of engine. But, If the timing mark is "dead on" it seems unlikly. What type of problem are you having? The distributor seems to be the usual problem. It would be easy to be one tooth off or even 180 out. Usually (on a V8) the dot on the cam gear and the dot on the crank gear point directly at each other for TDC (top dead center). At this point you can put in the distributor and see that the rotor button points at the #1 plug wire on the distributor cap. That is usually close enough to start the engine. smile
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
