Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rnl364, baldeagle), 56 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
Page 2 of 2 1 2
Originally Posted by oldieoldie
I’m going to try to take a brake fitting and weld it shut to make a plug. I’ve spent months trying to find a “made for it” plug with no luck. Anyone have any input on the idea? I’ve already welded them up but haven’t installed. All possible solutions are welcome. I want this on the road in the spring.
Show me a picture of where you need a plug...I'm confused. Is it on the Hydrovac or wheel cylinder???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Chris - In looking at your pictured wheel cylinders, I can't see what "port" you are trying to close up on them. I have an exploded brake diagram of your style setup below from a Chevrolet Truck Special Illustration book. The only added port plugs in that diagram appear to be the early style 2 piece bleeder valves. They were made up of a valve with a threaded hole for a 10-32x1/4 machine screw and washer to close the valve port. Later one piece bleeders (with the nipple for attaching a hose) have become the replacement for the old 2 piece valve.
EDIT: Mike B beat me to the post button. smile Leaving my post up in case the picture helps. wink
~ Dan
1951 Chevy 3 window 3100
On the wheel cylinder there is a place for the brake line to come in, a bleeder port, and a port for the jumper between the wheel cylinders. One cylinder brings in the brake line and has a bleeder and the jumper.( All ports are used). The second wheel cylinder has a bleeder and the jumper but there is no incoming line. This would need to be blocked off or your brake fluid would pour out.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
I see the problem now...your truck needs two different wheel cylinders on each side of the truck. The Rear, Front cylinders should have 4 tapped holes while the Rear, Rear cylinders should have 5 tapped holes.
Group 4.665
1951-52 Utility...Rear, Front...cast number 5453825-4...p/n 5453866.
1951-52 Utility...Rear, Rear...cast number 5453825-5...p/n 5453865.
If you look both of these part numbers up on the big auction site you can see the difference and they are available. The hole you're trying to plug isn't machined on the 5453866 part. Buy two of the correct cylinders and your problem is solved.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Great, thanks for the information. I was looking for a way to spend more money!
"I was looking for a way to spend more money!" ..so I went out and cast my gaze upon the ole' Big Bolt :-D (That always helps me find a way to spend any money I feel needs spending)..
True but I’d like to stay married.
Well, there's always that! dance
I guess I’m spending more money while the wife is out of town. But to clarify, all the old wheel cylinders had the same part number on them, even though the rear front ones were “missing” a hole. Odd.
They are the exact same casting (front and rear), they got a -4 or -5 for the part number (stamped on the box) to differentiate between the 4-hole and 5-hole.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I got the 4 hole cylinders and got one installed, hope to get other Monday and start putting fluid in it. I still need a vacuum line for the hydrovac.
7
7 Offline
If you can't fabricate 1/2" steel lines and don't want to use 1/2" copper, you could use 1/2" PEX tubing, easy to work with, inexpensive, won't collapse under vacuum.
Don't forget to install the vacuum check valve high on the firewall. It protects the Hydrovac and 2-speed rear (if you have one) if you should backfire through the carb.
The valve you need is Group 4.955 p/n 2214107...there's a coupe on the big auction site now...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I have the check valve but the huge metal vacuum line is broken. I’ll need to find it or come up with a suitable replacement.
Crusty Old Sarge
Crusty Old Sarge
oldieoldie, I sent you a PM.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
7
7 Offline
Is the line at the HydoVac unit the only one that is broken?
As far as I can tell. The other end at the check valve seems to be good. I’d like to change out the whole line for safety. I’m concerned about finding a connector for the hydrovac side since it looks like a big double flare.
7
7 Offline
It should be a 1/2" inverted flare, that is the same as brake line nuts, fuel line nuts, Napa should be able to help round one up or check Dorman parts online and get the part number. Edit- Dorman does not list a nut for 1/2 inch tube, McMaster-Carr has one but the price is stupid. Can you salvage the tube nut and fabricate a new nipple from soft copper, it only needs to be long enough to clamp some 1/2 inch hose on it. You could also remove the brass inverted flare x male pipe thread street 90, then you could use pipe thread fittings in place of the inverted flare. If you go that route, don't get too crazy when you tighten the pipe fitting into the cast aluminum HydroVac housing, it could crack easily.
7
7 Offline
Titan hydraulic fittings has it, [email protected] Denver Colorado
Crusty Old Sarge
Crusty Old Sarge
Just a picture to clarify my Hydrobooster setup. This is only meant to show the actual mounting of the booster and dual master cylinder.
Hydrobooster
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Page 2 of 2 1 2
