4 members (1955 1 Series, Ole49GMC, Otto Skorzeny, DaveV), 95 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#1573181 03/22/2025 7:54 PM
Anyone have a pic or diagram of how the antenna gets into the cab? Had to butcher two antennas together to get things working correctly and straight. Also had to make the hole in the cowell wayyyyy bigger.
Now I need to get it into the cab. There is a rubber boot, but nowhere is there a hole where the boot reaches to?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Factory AM antenna comes from the antenna being mounted on the passenger side cowl piece. One of the aftermarket places sells a template. Although, i used it and it's a little off. Best to use or find an original and make you own template. The antenna wire goes and enters the cab near a body seam under the side cowl which is about a nickel/quarter size and this should have a grommet of appropriate size. Maybe look on the inside of the truck under the dash top? Possibly it was repaired or filled in on the outside by a previous owner.
Very strange. There was an an antenna on the cowel, but it didn't go anywhere I remember. There was what I thought was a cb antenna center top, but after talking to daughter of original owner he had a radio mounted where I thought the CB was and the antenna out the top was for it.
Maybe the grandson attempted a radio install?
That would mean no factory hole.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
These are the pages from the 1960 factory install manual
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Well, I simply drilled a hole on a weld seam. Had to reverse the grommet for some reason, but it is in the cab and I am receiving sound waves!!!
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
