5 members (TUTS 59, 32Fordpuchoptop, ‘37ChevyPU, Barney1951, Cosmo), 118 guests, and 2 robots.
Topics128,050
Posts1,055,674
#1573427 03/25/2025 3:47 PM
I have an ignition resistor on the firewall of my 1950 pick up. It has been converted to 12 V.
Do I still need to use the ignition resistor?
Thanks, skinned knuckles
1 1951 Chev Panel with a 350 small block, automatic tranny.
1 2004 Chev 2500 HD pickup... stock
1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
Original 6 volt system didn't use a resistor, was added when converted to 12 volt. Should also have a by pass circuit to supply full system voltage to points while cranking, assuming it still has points.
BC
1960 C60 pasture art
Yes. Also called a ballast resistor. It is commonly used in 12 Volt conversions. It reduces the running voltage
to about 9 volts to protect the points. You should also have a bypass for starting on 12 volts if it is done correctly.
Fred
Drawing below was hacked out of a 1950 Chevy Truck wiring diagram. I removed everything except the ignition system. The red ballast resistor should be installed in the line between the ignition switch "run" terminal and coil +. The green wire needs to be added between the side terminal on the new "12 volt" stomp starter switch and coil +.
Great wiring diagram Bill!
A picture is with a thousand words.
