5 members (RLB, Tronman, pauld, JoeDude, 1 invisible), 135 guests, and 2 robots.
Topics128,201
Posts1,057,281
Members48,467
U
U Offline
I finally have my brake/clutch bracket completed and I'm ready to install my brake master cylinder. Does anyone know what this wire part is for and how it connects? Is this something one of the return springs connect to?
~ John in Utah
Here We Go
Follow in his DITY Bay
More than likely it connects to the brake pedal return spring.
Fred
U
U Offline
Maybe someone has pictures of how the springs are connected to the brake and clutch pedals?
~ John in Utah
Here We Go
My guess is it's the pedal return spring extender. The AD series trucks have something similar.
Here’s a pic I took before I disassembled not sure if it will help much.
Springs
Yep, that should be it right there.
U
U Offline
Thanks Rick! That might help. I'll need to find that extension bracket and wire. I'll look for them this afternoon.
~ John in Utah
Here We Go
U
U Offline
Anyone else out there with pictures of the clutch/brake pedals and how they have the return springs installed? Is that extension wire to the brake about 7 inches long? I could not find anything in my storage trays that looks like the "Z" shape bracket at the other end for the brake spring.
Kevin - On my wire that has a loop on one end and a hook on the other, do you know how the looped end connects to the brake pedal?
~ John in Utah
Here We Go
I found a picture on the web that may help.From a 1940 truck. From the VCCA site.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
On AD trucks, the anchor bracket for the springs is riveted to the frame. That Z shaped bracket would be pretty easy to fabricate if someone could share the dimensions with you.
The hook end of your extension wire would go on the brake pedal and then the spring would hook in the looped end.
You might PM Homer52. Dave has both a 1946 and a 1941 1/2 ton pickup and might be able to give you some more info. Although his 1946 is on an S10 chassis, the 1941 is stock. He might also have another truck of that era tucked away under a tarp.
U
U Offline
Kevinski - Thanks for the picture. I ordered the 7" hook-to-hook extension - I didn't want to use a coat hanger and have the hooks pull out. Also, I can probably make that offset bracket - looks pretty simple.
Kevin - I'll try to use my looped extension. If it doesn't work for me, I have a hook-to-hook extension coming in the mail.
~ John in Utah
Here We Go
U
U Offline
I connected the return spring for the clutch. For the brake spring it looks like my old setup had the extension wire on top of the clutch fork. You can see the worn groove on top. The bottom is smooth. I'll pick up some flat bar to make the offset bracket. I guess I could setup the bracket to allow the extension to go on top or bottom of the fork. I'll see what works best.
~ John in Utah
Here We Go
U
U Offline
Originally Posted by klhansen
...You might PM Homer52. Dave has both a 1946 and a 1941 1/2 ton pickup and might be able to give you some more info.
I was able to contact Homer52 and he sent me these photos of his pedal return spring setup on his '41 (photos look pretty similar). Nice little bracket that is bolted to the bellhousing. He said the brake spring goes under the clutch fork. I have two threaded holes in that location and now I'm thinking about fabricating a bracket similar to his. Looking at some old photos, I didn't have anything bolted there.
~ John in Utah
Here We Go
Cool, I figured that Dave might be able to help you out. thumbs_up
U
U Offline
Update: I made a bracket for the return springs, but now that I'm installing the engine side pans, the bracket is in the way. When I found my pans, it had a little bracket attached. I figured it was for one of the return springs, so I got it installed and here's how it looks now. I'm hoping this is correct.
~ John in Utah
Here We Go
John - See my latest reply in your DITY thread. smile
Edit Note: Kudo's to Kevinski who previously posted the picture (above) that I found in the link I posted there today.
~ Dan
1951 Chevy 3 window 3100
U
U Offline
OK - I found some GM springs and an extension wire. I believe this will be my brake/clutch pedal return spring setup. Thanks for all the input guys!
~ John in Utah
Here We Go
