3 members (1955 1 Series, TUTS 59, 1 invisible),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2024 Posts: 28 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 28 | In restoring my truck I replaced the damaged roof panel and discovered the rain gutter is designed to drain down and out through the inside back corners. Guess that is why the lower back corners always rust out. Is there a good reason not to drill drain holes through the gutter and seal up the back corner drains?
Last edited by Gdads51; 03/19/2025 11:31 PM. Reason: add detail to title for moving to the correct forum
GSS
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Gary, Your topic best fits in the Paint and Body Shop forum, so it's been moved there for further discussion and help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
